2001 Chrysler Van transmission
2001 CHRYSLER VAN
112,000 MILES • 4 CYL • AWD • AUTOMATIC
JOSH.JOHNSON1
i have a 2001 crysler town & country with 3.3 liter engine. when are start my veh.i can hear a rattleing
noise coming form the engine.when i put it drive to drive off it feel like it wants to stop on me.the veh.is vibrating also when i put it drive theres no power when i am trying to go up a hill and when i try to give it power the engine light will start flashing
Aug 30, 2009 at 1:01 PM
2CARPRO JACK
  • 11,533 POSTS
Start with a scan of the PCM to see if it has stored any trouble codes.Sounds like it may be running on 3 cylinders since it vibrating and trying to stall, low on power.A PCM scan should at least point to the cylinder that is bad.A 3.3 is a V-6, not a 4 cylinder.Those had alot of issues with breaking the cylinder heads where the rocker shaft bolts on, this could cause the noise and other issues you described
Sep 1, 2009 at 9:12 AM
