2000 Chrysler Van tightening sequence of connecting rod cap
2000 CHRYSLER VAN
111,300 MILES • 6 CYL • FWD • AUTOMATIC
DREWMAN1229
  • 6 POSTS
Each time I start to tighten my new connecting rod bearings onto the crank I cannot rotate the flywheel.
I had one bearing which was shot.
I know the torque is around 40 ft lbs!
I tried using the starter to tap it over but no dice. It wont turn it either.
The only thing I can think of is the sequence. Merry Xmas and I need a present quick or TNT.
Nov 28, 2008 at 5:14 PM
If its a 3.0L engine its 38ft lbs and 1/4 turn- try retorquing the main bearing cap loosen it and torque 8MM to 21ft lbs and 11MM to 30ft lbs and 1/4 turn
Note: Double check if its the correct undersize bearings
Nov 28, 2008 at 7:40 PM
DREWMAN1229
  • 6 POSTS
Thanks for the help
Nov 28, 2008 at 8:11 PM
