2007 Chrysler Town and Country right sliding door
2007 CHRYSLER TOWN AND COUNTRY
62,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHNWW
My right side sliding door will open part of the way and stop, also it will not close with the auto controller or button on the side of the b piller. Can you help? Door will open manual with no problems.
Nov 2, 2009 at 3:05 PM
CHRYSLERTECH
  • 11 POSTS
If the buttons do not work check your over head lock out button to make sure that is not on cause that will cause they buttons to not work.You can also have the codes pulled their will be stored codes for the power sliding door
Nov 3, 2009 at 10:52 AM
VIDEOJOCKY
I had this problem on the left side. The cable bundle sometimes breaks. The bundle sits inside a strap that runs in the channel at the bottom just inside the door. Sometimes a wire in the bundle will break, the bundle brand new is about $175. I just spliced the wire where it was broken with a crimpable wire connector, the toughest part was removing the panel on the inside of the sliding door. It took about an hour and a half, the major oart of the time was removing the and replacing the panel. Once you remove the wires from the chain conduit type of housing that the wires reaide in, it is just a matter of finding the wire that is broken. Hopefully it is not too close to the end where it comes out of the body, other wise you will have to buy a whole new cable bundle fromthe dealer. Good luck.
Jan 17, 2010 at 1:38 AM
