REMOVAL - 3.3L/3.8L
Disconnect and isolate negative battery cable.
Remove accessory drive belt.
Remove generator mounting bolts and reposition generator.
Unlock and disconnect the electrical connector from the EGR valve.
Remove the 2 EGR tube bolts.
Remove the 2 mounting bolts for the EGR valve and gasket.
INSTALLATION - 3.3L/3.8L
Install a new gasket on the EGR valve.
Position EGR valve to cylinder head and install the 2 mounting bolts.
Tighten EGR valve mounting bolts to 31 Nm (23 ft.lbs) .
Position EGR tube to EGR valve and install the 2 mounting bolts.
Tighten EGR tube mounting bolts to 13 Nm (115 in.lbs) .
Connect electrical connector to EGR valve.
Install generator mounting bolts.
Install accessory drive belt.
Connect negative battery cable.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Aug 8, 2010 at 12:30 AM
