2007 Chrysler Town and Country dr side slider
2007 CHRYSLER TOWN AND COUNTRY
RAY DICKERSON
  • 4 POSTS
Electrical problem
2007 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic 26k miles
when activated the slider opens 12in and stops if opened manually and activated remote/button inside car slider will close a bit over half way and stop
updated 2/2/10
I have ckd the mechanism from the fuel door to where it connects to the door lock unit on the car body and all appears to be ok is there a possibilty of the door lock/release unit be the problem i say this because when the door is closed and the open button is activated the door opens 12/14 inches and at that point there is a snap noise which appears to come from the lock unit on the door and the door stops your thoughts
Jan 23, 2010 at 12:25 PM
BMRFIXIT
  • 19,053 POSTS
1ST check the fuel door blocker striker entry into latch
if fuel door open Or not adjusted correctly slide door will not work correct
Jan 24, 2010 at 8:12 PM
BMRFIXIT
  • 19,053 POSTS
To prevent the door from hitting gas filler
have that safety feature, door will open about a foot and will feel like it hitting a stopper
using a scanner tool you can check if have a door actuator problem and or an electrical issue
Feb 5, 2010 at 8:39 PM
