Yes the belt in on correctly. I had the flap problem last August and at that time I replaced the water pump, altenator and belt and the problem went away till Feburary of this year. I was on my way to Florida. It flaped for a day or so and then went away.
It returned late June this year. Replaced the belt still flaped. Replaced the tightner and it still flaped. With the transmision in park the belt doesn't flap. You turn on the AC on or off and no flap. Put the transmission in drive and the belt begins to flap. While in drive the belt will STOP flapping when the engine RPM slows down to about 600. Increase the RPM and the belt will flap between 650 to 850 RPM. 750 being the point where flap is the worse. With some one else holding the brake down I can observe about 1/2 inch of flap between the harmonic balancer pully and the A/C pulley. All of the pullies are running true. The belt tightner pully is moving to take up the belt slack.
With the belt off I have checked the all of the pullies for roughness and bearing problems by turning them. Nothing evident.
I got up yesterday and thougnt I would make a table of what I observed to help the mechanic figure out what to replace next. Started it up and backed it out of the garague. NO flap. Drove it around town and NO flap.
I tried the broom handle trick to listen to the altenator. NO bearing noise. NO AC bearing noise.
The only thing I can say definitly is it will only flap when the transmission is in drive and I stop at a stop light. People start looking around to see where the nose is comming from.
Could this be a transmission problem?
Expensive to have it repaired and it isnt the problem!
Same for the AC
Thanks for your help.
This may be a good problem to stump your mechanic friends with.
Oct 18, 2020 at 12:13 PM
(Merged)
