2005 Chrysler Town and Country water condisation leaking in
2005 CHRYSLER TOWN AND COUNTRY
55,000 MILES • 4 CYL • FWD • AUTOMATIC
DEPUTY1186
it appears that water has been leaking from condisation build up into the van. I know normally it drains out if the vehicle but now its leaking into the interior. do I need to change a gasket? what are the possible other problems?
Thanks
Sep 28, 2008 at 8:39 PM
Hi:
Do you mean the problem is coming from the AC? If so, there are no gaskets only a drain. It's common for the drains to clog and cause the water to come into the vehicle. The drain on your vehicle should be located on the passanger side lower portion of the firewall. It will be a black rubber hose with a 90degree facing down. Move it around or try carefully placing something up in it to open any blockage. NOTE: If this is the problem, you may get wet.
If the problem doesn't occurr with the AC, let me know. It may be a leak from the windshield.
Oct 5, 2008 at 11:10 PM
