Engine Cooling problem
2005 Chrysler Town and Country Two Wheel Drive 87000 miles
If the radiator cap is not fully tightened can you drive this car without a major overheating to occur? If it doesn't over heat can it still loose fluid? If it looses fluid and the cap is still not fully tightened can it then overheat? Can over heating cause a leak in the radiator?
Aug 28, 2008 at 4:06 PM
