engine knocking
2005 CHRYSLER TOWN AND COUNTRY
179,000 MILES • 6 CYL • FWD • AUTOMATIC
ANITAH
Started knocking 2 days ago. Discovered it was 3 quarts low on oil. It is not leaking. Put oil in. Knocking has become worse. Really bad when accelerating. I just checked the oil and it is 1/2 quart low already. It has not overheated. The oil light never came on. The check engine light is not on. I can feel the knocking in the gas pedal as I accelerate.
Jul 12, 2010 at 4:21 PM
MERLIN2021
  • 17,250 POSTS
If it is engine related, knocking is either a rod bearing, or wrist pin on the connecting rod of one of the pistons. You will need to install a crankshaft kit or just get other engine.
I crankshaft kit will cost about $1600.00 while a used engine should be about $2500.00
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
Jul 12, 2010 at 4:39 PM
