I have a 2004 Chy T&C, 3.8 liter. I had a bad sensor #1, I replaced both sensors. I still have a couple of codes p032 and P038. The heater circuit high volage on both sensors. From what i have read, this is related to a blown fuse or bad ground wire. I pulled every fuse under the hood and they all look good. I have not been able to locate any other fuse blocks.
1. Is this a fuse issue?
2. Where would the fuse be?
3. Any other toughts would be appreciated
At the same time this occured, the low beam onthe drivers side went out. I changestyhe light bulbs and the front control module to no avail. I do not know if they are related.
Oct 3, 2009 at 9:39 PM
