I'm trying to change the water pump on my 2003 T&C (3.8 L) using the instructions off Alldata. I've run into a big problem - there isn't enough clearance between the water pump & adjacent frame member to get the pump out! The instructions make it sound like you just take the bolts off and remove the pump (even the Chrysler instructions read this way!), but when I slide the pump out of its body on the block, the pump shaft bangs against the adjacent frame member before there's enough room for the pump impeller to clear the pump body. I need another 1/4 - 1/2 inch. I've tried moving the pump up, down, and side-to-side to find a little more clearance with no luck. %$#&*!
Does anyone have a tip/trick to get the pump out ( and new one in)? Right now, I'm thinking I'll have to support the engine under the oil pan with a jack, then unbolt the right side engine mount and lower the whole engine about an inch until the pump clears the frame member.
I'd appreciate a response ASAP!
Thanks!
Thanks!
Oct 27, 2007 at 6:40 PM
