2002 Chrysler Town and Country Thermostat
2002 CHRYSLER TOWN AND COUNTRY
88,000 MILES • 6 CYL • FWD • AUTOMATIC
HERRNOEL
Engine temperature gage stays at zero when running at highway speeds and heater barley warms uP. When parked with engine running the temp gage comes up about a quarter instead of where it normally comes up to almost halfway. I suspect the thermostat. How hard is it to change the thermostat?
Jan 5, 2010 at 2:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL: 1.Disconnect the negative battery cable. 2.Place a drain pan under the radiator drain and drain the cooling system to just below the thermostat level. Close the drain. 3.Remove the upper radiator hose from the thermostat housing, then remove the housing. 4.Remove the thermostat and discard the gasket. 3.0L shown, others similar
https://www.2carpros.com/forum/automotive_pictures/261618_1_89.jpg
INSTALLATION: 1.Clean the housing mating surfaces. 2.Dip the new gasket in clean water and place it on the water box surface. 3.Center the thermostat on the gasket, in the water box. 4.Make certain the bolt threads are clean. Threaded bolt holes exposed to coolant are subject to corrosion and should be cleaned with a small wire brush or correct size thread-cutting tap. Install the housing, making sure the thermostat is still in the recess, and tighten the retaining bolts to 105 inch lbs. (12 Nm) for 3.0L engine or to 21 ft. lbs. (28 Nm) for 3.3L and 3.8L engines. Reconnect the upper radiator hose and tighten the hose clamp. 5.Connect the negative battery cable. 6.Fill and bleed the engine cooling system with a clean 50 / 50 mixture of ethylene glycol antifreeze and water. 7.Make sure the radiator is full and start the vehicle. CAUTION Do not remove the radiator cap once the vehicle is warm. Coolant is under pressure and may cause scalding or personal injury. 8.Run the vehicle until the thermostat opens. Check the coolant level in the overflow tank and fill if necessary. 9.Pressure test for leaks.
Jan 8, 2010 at 8:46 PM
