The check engine and battery light is on, ran a scan and came up with po107(map), p122(tps), which was changed, and po106, po205, p1478,p1496. only tps was changed, same results. Also black carbon from tail pipe. Cleared codes and they all came back, disconnected battery codes came back. Noticed a buzzing noise on and off on drivers side.Also changed battery.The idle is rough, rpm jumps up and down, drove it a short distance, and could not shift from second gear. Any Idea what could be wrong
Thanks for any help
10/5/08
Sorry did not realize it was posted on the web site, was looking for an email. great anwser, because we heard a buzzing noise coming from the driver side before the problem happened. Need to know if i should buy a new pcm?
Thanks for any help
10/5/08
Sep 30, 2008 at 9:25 PM
