I have done a lot of work on mini vans. I have replaced transmissions and rack & pinion just to let you know that I have a good idea of the front end. There is grease coming out from the front tire wheel well. I think it is coming from the hub seal. The question is - can I remove the (obviously removing the wheel and axle nut)
hub and replace the axle bearing seal without removing the strut or compressing the strut?
Mar 29, 2009 at 10:09 PM
