2000 Chrysler Town and Country prndl
2000 CHRYSLER TOWN AND COUNTRY
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
DODGER140
all the lights on my gear shifter are luminated. my speedometer was'nt working until i changed the speed sensors. the lights are still on and my tranny wont shift. i think its stuck in second gear. have any ideas?.....speedometer stopped working again today
Oct 18, 2009 at 8:42 PM
CH112063
  • 1,320 POSTS
Try replacing the two lower switches next to each other on the corner. They may be bad also. Then disconnect the battery for 30 secponds. Start and check fluid in Park, hot, before checking and having it looked at. The switch facing the front is called a range switch. The other is called a Park Neutral switch. A PRNDL. Prindle switch. If the fluid smells burnt, at least you will know it needs lots of work. The valve body inside contacts these switches and also breaks sometimes. It requires removal of the pan to check that. Be careful please. They have different threads so you can't mix them up. The plug may have came off one. There is a fuse involved.
Oct 20, 2009 at 9:10 PM
