Engine not cranking over - bad starter?
1998 CHRYSLER TOWN AND COUNTRY
HMZJACKS
Please help, at a total loss. Have a 3.8 liter V6 with 161,000 miles. I have spent a lot of money in diagnostic repair bills.
Problem: After the van has been driven for a while and turned off, sometimes, with no warning, when I turn the key to start the engine nothing happens, the engine will not turn over. All lights (inside and outside) work, the van will not make a sound.
I have had the vehicle towed, several times. As usual, when the mechanics finally get to it, the van starts right up. The pattern seems to be; van will initially start, then unexpectedly, days or weeks later after the van is driven and turned off, the van will not start. Or, if it does start, it will sputter and shut off.
After a time or two, it will not start back up.
However, after letting the van rest an hour or so, the van will start right up and run again until the problem repeats itself. Could something be loose causing the problem or something more?
Diagnostics have been completed and no codes have been found by the mechanic, because, the van works fine when by the time the mechanic gets it. Anything you can do to help would be greatly appreciated. I do not want my wife and children to be stranded again.
Aug 16, 2007 at 12:15 AM
VERBAKINT75
  • 4 POSTS
The best solution seems to be whacking the dash, because there is faulty wiring there causing the problem. Oh, by the way, a bit of info that helped me; the Town and Country has an anti-theft system that seems to make the key inoperable after several failed start attempts. This is the most likely reason that turning your key produces nothing but a bad instrument panel after several failed start attempts.
These guide can help fix it
https://www.2carpros.com/articles/starter-not-working-repair
and
https://www.2carpros.com/articles/how-to-reset-a-security-system
Aug 16, 2007 at 5:51 AM
CEDRLM
I recently purchased a 1997 Town and Country with 180,000 miles. After about a month I ran into this starting problem. Hitting the dash did not work. But, I opened the driver's door and tried to start it, I wanted to see if I could hear any relays clicking. The van started. Today it did not want to start again, I held the key in the start position and opened the driver's door and it fired right up.
I have to laugh at this.
Sep 15, 2007 at 8:23 PM
FRABLA
  • 6 POSTS
My 1998 Town and Country LXI has same issues. Will start fine usually but will not start sometimes. Today would not start at all. I have hit the dash, opened the doors, disconnected,charged and reconnected battery, jump started, replaced starter and battery previously, had towed in only to have start right up at shop, etc,etc. I will not let my wife drive it anymore. Has become totally unreliable and will need to go unless somebody has any ideas. Sometimes it will start if on a hill and put in neutral and roll and start. Kind of inconvenient. I believe it has to do with alarm or ABS system or possibly the transmission sensor switch. If anyone knows how to disconnect the alarm system or override it advise please.
Apr 21, 2009 at 10:22 AM
PASEAJ
I had my van not working after a long road trip of 4,000 miles. It just suddenly stopped running while idling. I tried detaching the battery, nothing. Whacking the dash, nothing. Then I tried opening the door while turning the key, Varoom! Thanks! Apparently it had something to do with the SKIM security shut down.
I love 2CARPROS.com!
Poochie Jones
Jan 16, 2010 at 2:49 PM
ANONNICK
My 2001 will start and then shut down after three or four seconds. It will do this over and over, as if you were trying to start it without a "chipped" key.
It was really starting to seriously irk me, so in frustration one day I pulled the tilt bar toward me and vigorously bounced the tilt wheel up and down. I then turned the key and "viola", started right up.
It seems to be doing it more often than ever before now and that is how I have to start the stupid thing. Some type of electrical failure I am sure.
May 19, 2012 at 2:00 AM
SUNNI63
Hi everyone, I have a 1998 Town and Country LXI. I too had the problem of it not starting and having to bang the dash the problem at least for me was the computer for the dashboard needed to be replaced my guy was able to re-solder it (until I can by the new one) and for the last four months it has been working fine.
Jun 17, 2012 at 11:36 PM
When this happens, do this. Have a helper turn the key to the start position while you check for voltage at the smaller wire on the starter. You should have twelve volts. If you do, replace the starter. If not, check the stater relay.
Jun 26, 2012 at 2:32 AM
JOSEPH BALCEREK
I have a 1997 Town and Country LXI. it has multiple electric problems. The two most common are the start for two to four seconds then shut off. Smack the top of dash. It starts. That was a failing wire connection in harness. It is under dash about directly below steering wheel. Down low, a rectangular "box" type junction. What wire ? Your guess is as good as mine. Chrysler dealers deny, deny, deny that is the problem and will not give a satisfactory solution. Do not buy a computer!
The second problem is after driving and making a few stops. Shutting it off and restarts. Then it will not start. But dash lights light as supposed to. But no sound "click" mine just started playing that game
Ha ha . believe is a relay problem, as after it sits and cools down, it starts right up! Do not be too quick to call for a tow. If it does not start after two or three tries wait half an hour to forty five minutes.
Electrical problems are hard and expensive to diagnose. Best to find someone familiar to the vehicle who is honest
Mopar has been known for "crazy"electrical problems for years. Good luck.
Jun 26, 2016 at 7:06 PM
