heater will not work?
1998 CHRYSLER TOWN AND COUNTRY
140,000 MILES • 6 CYL • FWD • AUTOMATIC
SKITOWN231
i have dual climate control and when i start my van the driver side heat works good but the passenger side heat blows out cold air the whole time the van is running the knob that you can turn to make the heat go the the floor , defrost, the top, ect is broke and even if i turn it to anything it still stays on defrost the knob is not lose but when i turn it it turns freely like its not catching anything it just spins what can i do to get my van heat back on both sides
Jan 6, 2010 at 2:25 PM
at first, it sounds like you have a vacuum leak. THe vent doors that change the air direction are vacuum actuated. If the knob spins, either the knob is stripped or the switch is bad. Can you remove the knob? If you can, does the shaft it attaches to spin freely?
Please check out this guide to help fix the problem
https://www.2carpros.com/articles/car-heater-not-working
Jan 18, 2010 at 10:42 PM
ASHLEYMERRITT1987
my heater isnt working just blowing cold air and van is smoking. i put coolant in and the heater works until the next day then doesnt work again. the needle stays in the middle.
Nov 18, 2020 at 8:02 AM (Merged)
If it is stearming, there is a coolant leak. If the coolant gets low, you will lose heat. Locate the leak, repair it, and fill the coolant and you should be find. Let me know if you have other questions.
JBURGMANN
i have a 1996 town and country with no heat on the drivers side. i ran a calibration test on the front panel and it said there was a problem with the "zone/driver actuator did not reach heat stopzone/driver actuator did not reach heat stop" i figured the actuator went bad so i got a new one, replaced it and now i get the code "blend pass. actuator did not reach heat stop ". is this more of a mechanical problem with the doors themselves or did i do something wrong when i installed the actuators?
to be a little more specific, when i took off the passenger actuator i noticed there was a small grey square shaft sticking out of the heater housing. when i tool off the drivers side actuator i did not see the same shaft. is something missing, or broken as well?
and how do i check to make sure the doors are not stuck?
Thanks,
Jon B
I would have to see the shaft you are refering to. As far as checking for operation, when adjusting the temp, they should open and close a distance based on the temperature requested.
CRAZYOVER40
had heat this morning, went to store came out driving home no heat just blowing cold air. Rear defroster/rear wipers nothing lights won't even show up on rear buttons. Replaced thermostate, coolant is the right level, heater hoses warm, coolant in radiator hot car is still blowing cold air. What could be wrong???
Check the heater core whether its clogged up. Heater hoses are they both the same temperature. If not a clogged heater core.
Could be a problem with air mix/blend/mode door not opening or an actuator/vacuum.
The HVAC control module is the heart of the system this one goes you need to bring it in to read out the codes on actuator calibration/diagnostics and cooldown tests
MIKE H R
  • 3,094 POSTS
check the fuses, with no lights working check for blown fuses.
