checked relays. and fuses, replaced fuel pump and filter,new coil pack, new crank sensor. Plugs and wires ak. Cylinder 3&4 is grounded before the key is turned on, something grounding out inside the pcm before the key is turned on(pcm is hot even when not on) engine won't start lup, how do you get code readings, did try removing sensors and replacing one at a time(only time we got a code reading)
Sep 9, 2009 at 4:26 PM
