1996 Chrysler Town and Country Transmission Not changing ge
1996 CHRYSLER TOWN AND COUNTRY
163,000 MILES • 6 CYL • 2WD • AUTOMATIC
SERENA96
1996 Chrysler Town and Country LXI with 4 speed transmission:Transmission Selinoid was leaking, changed and now van ran fine then two days later got code (PO500) indicating speed sensor is bad. Changed both inner and outer and ran fine for a day and now it is doing the same thing again: not changing gears but will change gears if I let it worm up for about a half hour or continue to rev it up, it wll evantually catch and the speedometer will work but if if I let it sit for about an hour the problem will start all over again. Please help.
Feb 22, 2009 at 5:24 PM
BMRFIXIT
  • 19,053 POSTS
Check for codes again
if possible scan the TCM for codes
suspect tranny solenoid pack
Feb 22, 2009 at 6:12 PM
