1996 Chrysler Town and Country Power steering pump
1996 CHRYSLER TOWN AND COUNTRY
135,500 MILES • 6 CYL • FWD • AUTOMATIC
OLAUNDAJOHNSON
MEMBER
FOLLOW
how do you change power steering pump? Trying to change p.s. pulley, but having a hard time.
Feb 21, 2010 at 8:08 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
which engine size? 3.0L, 3.3L etc..?
Feb 21, 2010 at 8:12 PM
OLAUNDAJOHNSON
MEMBER
3.3 6cyl. should we replace the whole pump not just the pulley? while at idle and while driving, car makes a ticking noise. mechanic says its p.s. pump. i have no clue?
Feb 21, 2010 at 11:20 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
its possible for power steering pump to make ticking noise if its failing. you will need the pump not just pulley if that is what has been diagnosed. replacement steps are below..
Feb 21, 2010 at 11:27 PM
OLAUNDAJOHNSON
MEMBER
ok we took out the pump, and wanted to know if there is supposed to be any back and forth play in the pulley? there is no side to side. and the old pulley had a crack in, would that have caused the ticking? And if there is not suppose to be any play, we would need a new pump, yes?
Feb 22, 2010 at 1:18 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
no should have no play at all any direction. if pulley is cracked then it may the cause of the noise and not the pump itself
Feb 22, 2010 at 1:31 PM
GREGEVE93
MEMBER
[quote:8ac097da89="olaundajohnson"]1996 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic 135500 miles
how do you change power steering pump? Trying to change p.s. pulley, but having a hard time.[/quote:8ac097da89] I just changed mine and i had to have the pulley pressed on but had to take off the back or outer housing 1st!I droped the cv joint down/Not out!!If you would like to talk ,email me with your number and i can explain in detail.Good luck Greg. [email protected]
