Hi Ken, I tested for spark after I pulled battery negative and checked resistances to most of the sensors for obvious shorts or open circuits (via the lifted PCM connectors), only the pin 6 line from the PCM connector to the ASD relay was questionable at 2.5 ohms (this also goes to the Generator, Distributor, and to fuse 1 of the PDC. Then I set up to test spark on the no. 6 plug, Wife assist mode with instructions "shut down immediately if engine starts". Of course it did, so I put it all back together and wonder what the next step should be. Seems to be triggered when the car sits for more than a couple days but doesn't seem to be a battery issue as I put a full charge on the battery overnight before attempting to start it, also pulled B+, none of which worked. Has anyone published a list of resistance values for the sensors on this car? I know when the Hall effect crank sensor went bad, I was able to rig up a circuit with my scope, B+ and ground, sensor output, a piece of ferrous metal,and passed it back and forth past the metal and could see the output on the scope. Thanks
Sep 24, 2019 at 5:44 PM
