Bubbling air in the reservoir
CHRYSLER SEBRING
DFULLER
My wife drives a 2001 Chrysler Sebring Limited convertible with 105,000 miles on a 2.7 Liter, 24 valve DOHC. Afrer driving for any extended period of time, I have recently notice that there is a bubbling sound coming from under the hood. When I raise the hood, I notice the sound is coming from the Radiator water reservoir. At first I thought the water was boiling but after a closer look, it seems like mabye short bursts of air are going into it and making the water bubble. Each bubbling sequence lasts about 2 seconds or so and they are a couple of seconds apart. The car does not seem to be overheating as the dashboard temperature gauge stays just below the 50% mark throughout the drive. We are running the air conditioning while driving. Any ideas what could be causing this?
Thanks for your help,
Dennis
Memphis, TN
May 13, 2007 at 4:10 PM
SERVICE WRITER
  • 9,123 POSTS
If a headgasket ruptures onto the cooling system, it can pressurize the cooling system and cause bubbles like this. There is a chemical that can be added to the coolant that will tell you if it is exhaust gases.
May 13, 2007 at 5:51 PM
