2008 Chrysler Sebring scary noises!
2008 CHRYSLER SEBRING
30,000 MILES • 6 CYL • 4WD • AUTOMATIC
NICOLEMC
most of the noises occur when i brake (a low grinding and rattling sound) but they also randomly occur while i'm driving, mostly in the city (a low "womp-womp-womp" sound accompanied by rattling). i've taken good care of the car over the past couple years but really can't afford serious costly repairs. i know i need to get it taken care of, i don't want to cause any accidents or further damage but i'm scared to take it to the dealership because i don't have the money it will probably require. please help!
Mar 12, 2010 at 10:00 PM
ERNEST CLARK
  • 1,730 POSTS
Is your car still under warranty??? I would think you still have many miles left.
Anyway, it's quite possible you have more than one issue.
A "Low grinding and rattling sound" when you apply the brakes is either excessively worn brake pads or loose/missing retainer springs.
The "womp, womp, womp" that you hear while driving could be a warped rotor, which can occur if your pads were excessively worn and overheated the rotors.
Also a common noise for vehicles with alloy rims that have "Center caps" is the tension spring sometimes comes loose/falls out on the inside. This will make an intermittent rattle while driving.
Finally, whatever your issue turns out to be, you never want to keep driving a vehicle when there's a suspected brake problem.
You're taking unnecessary risk with your life as well as others!
Mar 15, 2010 at 10:44 PM
