2005 Chrysler Sebring condensate leak into cabin
2005 CHRYSLER SEBRING
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
CIE7359
Sebring sedan is experiencing a condensate leak into cabin under passengers front seat, not thru firewall. Is this from a clogged/collapsed condesate line? How do I locate and repair?
Sep 16, 2010 at 6:37 AM
WRENCHTECH
  • 20,761 POSTS
Locate the drain at the outside of the firewall and use either compressed air or a coathanger to clear out the drain. Also make sure there is a rubber downspout attached to the drain nipple. Without it the water will drip off the end and siphon back along the outside of the pipe and back int the passenger compartment.
Sep 16, 2010 at 7:39 AM
