air conditioner works on and off when it works everything is cold as ice Freon level is perfect and pressures are perfect when compressor is engaged had it checked by a shop I have a code of p1598 ac pressure switch voltage to high cant find a cause other than computer being bad problem seems to occur at the hottest parts of the day around 1100 am thru 430 pm after that i have yet been able to recreate the issue i am looking for maybe some way of troubleshooting it or maybe you might have had this issue and know the fix for it as guessing and just replacing parts for this system is extremely costly thanks in advance for your time and energy in this matter and feel free to contact me if you need anything further
Jun 12, 2008 at 2:07 PM
