There is the odor of gasoline inside car, inside engine. THere are no gas leaks. A mechanic told me it was the injectors.
Jul 25, 2010 at 10:48 AM
EDWARD.S
CERTIFIED EXPERT
Hi, It Is Possible For The injectors To been leaking , However ,Have The Fuel Tank ,And lines Checked for Leaks.This Is Done With a Smoke machine .If your injectors are leaking ,You Should be able to see gas Around them .Shine a Flashlight At each injector And see if it's wet with gas.If so You need To get them replaced.ASAP.
