2000 Chrysler Sebring
2000 CHRYSLER SEBRING
RACEMOM
  • 4 POSTS
Engine Cooling problem
2000 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
the car continues to overheat, have replaced thermostat, water pump, radiator, radiator fan motor, and radiator cap. Have had it tested for blown head gasket and that's not the problem. Have checked the relay and seem fine. But the fan seems not to be working correctly. When the relays are out and you jumper the fan it comes on and runs. But the fan doesn't seem to come on and stay on when it should. When you turn the a/c shouldn't the fan come on and stay on? And it doesn't the fan cuts in and out, and the temperature gauage in at half way and the fan isn't running. Any ideas on what the problem could be? When you hot wire the fan to run all the time it has no problems.
Oct 25, 2008 at 11:37 AM
DOCFIXIT
  • 18,828 POSTS
Fan problem there are 4 relays and a temp sender to check. Click pon site at bottom of reply manuals
Oct 25, 2008 at 11:43 AM
RACEMOM
  • 4 POSTS
where would the other 2 sesnors be to check and the temp sender isn't that by the thermostat housing - how would you check that thing
Oct 25, 2008 at 12:04 PM
DOCFIXIT
  • 18,828 POSTS
Click on site at bottom of reply ie manuals and for $9.95 you will detailed instruction and wiring diagrams. The relays are in box underhood and temp sender is by thermo. an Ohm test also a scanner is used.
Oct 25, 2008 at 12:25 PM
