1999 Chrysler Sebring EGR valve replacement
1999 CHRYSLER SEBRING
10,500 MILES • 6 CYL • 2WD • AUTOMATIC
GOLDIEGOPHER
I had someone read the code with an analyser and it said to replace the EGR valve. It looks easy to replace but I think I need to remove some equipment befor I can remove tha install the new unit. What is the proper sequence for this repair? Thank you
May 14, 2010 at 4:13 PM
2CARPRO JACK
  • 11,533 POSTS
The valve is mounted on the back of the passenger side cylinder head.You will need to remove the air intake hose to be able to access it.Use a mirror to locate the mounting bolts that hold it to the head and the pipes to it.from there it should just be a unbolt one bolt in the other project
Jun 25, 2010 at 4:59 PM
