1999 Chrysler Sebring brake lights
1999 CHRYSLER SEBRING
16,000 MILES • 6 CYL • FWD • AUTOMATIC
MELODYESWEETIN
My tail lights & hazard lights work, but I have no break lights. What should I look at to fix this?
Oct 29, 2010 at 8:44 AM
JDL
  • 16,098 POSTS
Check fuse 4--20amp, underhood fuse block. Not only check the fuse, use voltage tester on fuse circuit, should be hot all the time. Next, I'd check voltage to and from the brake switch, the brake switch should be activated by the brake pedal arm.
https://www.2carpros.com/forum/automotive_pictures/170934_sebring_brake_switch_1.jpg
Oct 29, 2010 at 2:27 PM
