Alarm system
1999 CHRYSLER SEBRING
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
BENSELBY
the car will not start due t the ALARM SYSTEM, we thought it was the battery and replaced it and it started but then would not start again, alarm system not allowing to car to start.
Apr 13, 2009 at 8:21 AM
CARADIODOC
  • 34,306 POSTS
Are you unlocking it with the key fob or the key? If the key in the lock cylinder, try it in the other front door. If that works, the switch in the left door is disconnected, defective, or there's a broken wire between the two door hinges.
Here is a guide to help you reset the system
https://www.2carpros.com/articles/how-to-reset-a-security-system
Apr 14, 2009 at 2:45 AM
FROSTY1269
Thanks for this guide worked perfect. I love this site.
Dec 8, 2018 at 2:00 PM
RONDO123
i let my car sit over the winter-it was perfect before -wont start-fuses checked -tried to jump &trickle charged the battery-could it have something to do with the anti-theft circuitry?or reseting something ?cranks but wont startcould someting go without using it at all?
Dec 8, 2018 at 2:01 PM (Merged)
BLACKOP555
  • 10,386 POSTS
if it was antitheft related the light would be on and chances are it wouldnt crank AT ALL.
i would be checking for spark at this point, should be bright and blue.
do use a spark plug tester please.
get back
DAZE446
My alarm was going off on my car and my remote would not shut it off. I disconnected the battery now my car will not start. Is there a reset or something I need to do to the alarm to start my car up again. I have had no other electrical problems in the past. thanks Dave
ZACKMAN
  • 4,202 POSTS
Use the key to lock and unlock the DRIVER door. That should reset the system. If i doesnt then I would replace the drivers door latch because there is a switch inside the latch that goes bad which cases the alarms to go off.
DAZE446
[quote:d505b86a35="Zackman"]Use the key to lock and unlock the DRIVER door. That should reset the system.[/quote:d505b86a35] Thanks for the help it worked.
ZACKMAN
  • 4,202 POSTS
Glad I can help. Come back soon..
BUDMANN
  • 4 POSTS
I cant get the alarm to set. Tried the key things. Last time i got it to set. Set it off turned it off car started fine. Drove a few places. Started fine every time. Til the last time. Now cant get the alarm to set
Aug 5, 2019 at 4:37 PM
What happens is the driver door latch/pin switch wears out so it doesn't work the micro switch inside the latch so the alarm thinks the door is still open. To be sure we can do a test to see if the switch is being closed. here is a guide and the security system wiring diagrams to help you see how the system works and which wires to test:
Aug 6, 2019 at 10:22 AM
BUDMANN
  • 4 POSTS
So today i unhooked negative cable. Let it sit for 20 minutes. Then got it to start. It ran great for 5 minutes or so then just shut off. Started right back up. Ran for 5 minutes and shut off again. Now it wont start again. Did the battery thing again, the key thing, got the alarm to turn on and go off but wont fire just cranks. I am thinking the key maybe? He only has one and it says valet key on it. Any suggestions?
Aug 10, 2019 at 9:05 PM
Yep, it sounds like you have the wrong key or it lost its programming which happens. When it wont start does the security light flash? if so this is what is happening. I shop can reprogram a key for you it should cost about $130.00, let me know.
Aug 13, 2019 at 10:26 AM
NATE DAW
I am having a no start issue with me 1998 Chrysler Sebring convertible JXi. Key and key fob work to lock and unlock car. Security light isn't on, but the car won't even crank. I have power to everything but no start. Any help is useful and appreciated.
Apr 17, 2022 at 6:35 PM
Hi Nate,
It sounds like it could be a few different things. What I need you to do is this. Because the vehicle is a different year and is a convertible, I need you to start a new thread. All you need to do is copy and paste your question and it will get answered.
Please note: We do this to keep threads specific to one topic so that it is more helpful to others. I hope you understand.
Here is a link to start a new post:
Again, I hope you understand. I will watch for your new question.
Apr 19, 2022 at 7:53 PM
