1998 Chrysler Sebring Tune up
1998 CHRYSLER SEBRING
232,000 MILES • 6 CYL • FWD • AUTOMATIC
LDAVE1975
I put new spark plugs and wires.It still missed out so I put a new rotor button on and still missed out so I put a new distributor on it started but still was missing so I took out distributor and reinstalled it and it wouldn't even fire so i took it out and put it back again and now it fires but won't start.What could be wrong with it the distributor only goes in one way so I know it's not wrong.Please help me?
Mar 4, 2009 at 9:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure you have the firing order of plug wires correct.. Firing Order: 1-2-3-4-5-6 Distributor Rotation: Counterclockwise
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528003952e_2.jpg
Thanks for using 2CarPros.com!
Mar 5, 2009 at 12:40 AM
LDAVE1975
Firing order is correct.Did I mention car had a bad miss before I changed anything.
Mar 6, 2009 at 5:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Several things can cause a misfire or no fire situation. You need to inspect the following components..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_291.jpg
Post results and I will follow up. Thanks for using 2CarPros.com!
Mar 6, 2009 at 5:27 PM
