Transmission problem
1998 Chrysler Sebring 6 cyl Front Wheel Drive 140000 miles
I replaced the ECM. Now the car is stuck in "overdrive" and will not shift into 4th gear so I can't drive over 35mph. I've replaced the engine speed sensor without any change. Also the SRS dash indicator is on. This model has an "overdrive" button on the shifter. When the overdrive is engaged, the car stays in third. Normal driving is with the overdrive not engaged. The button on the shifter does not work now, thus the car is "stuck" in OD. Also the OD dash indicator light is not on. I had the computer checked and it is functioning as it should be. I was told one of the wires from the ECM or TCM bundle could be not working, but there are hundreds in the bundle and how do I know which wire it would be. Is this a reasonable explanation? Could it be a wire in the wire bundle or something else? I need help.
Oct 14, 2010 at 2:08 PM
