Electrical problem
1997 Chrysler Sebring 6 cyl Front Wheel Drive 120,00 miles
any time you enter or exit the car all dash lights and hazard lights flash about 20 times then stops. then 20 times then stops. this goes on and will not stop.
the keyless entry fob stopped working altough it checks good on a remote tester.
tried locking and unlocking doors with key, but nothing will stop this flashing.
i am happy the horn is not sounding when this is happening (the horn does work when pressed)
does the entry fob need reprogramed. this all started when the battery was replaced.
can you help
I can't use a obd scanner because it won't power up when connected to the DLC . would you have an image of the 97 sebring dlc so i can tell which is pin 1 and pin 4 . i can't see in the position it is in. what fuse is used for the DLC. maybe the reason it won't power up the scanner. all fuses good, still no power to dlc.please HELP
can you help
Jun 28, 2010 at 3:55 PM
