hey, I would appreciate any input on this. When ever i go to start my car in the morning it usually takes 2-3 revolutions before it catches, i'm not exactly sure if that's normal, but the real problem is immediately after i depress the gas pedal still in park the car suddenly idles erratically and struggles to stay running then shuts off. then when i go to try and start it again it takes 4-5 revolutions of the engine to start as if it is being starved of either gas,spark or air. what could be the problem? tps,iac perhaps? the only time this does not occur is whenever i leave the car idling for at least 5-10 without touching the gas pedal then it behaves and i can rev it in park without it shutting off on me. the injectors are clean,new distributor cap,fuel pump is working ,i can't figure it out.
Mar 15, 2009 at 10:58 PM
