The air conditioning compressor clutch will not engage. The system is properly charged, the high-low switch has been replaced, the relay is good. The compressor clutch will engage when the ground side of the relay coil is bypassed, and then, the system does cool. According to the wiring diagragm, the ecm is connected to the AC control circuit. What part does it play, and are there any other switches or sensors in the system that I may have overlooked? Thank you in advance.
Apr 23, 2009 at 10:11 AM
