1997 Chrysler Sebring Charging system issue
1997 CHRYSLER SEBRING
135,000 MILES • 6 CYL • FWD • AUTOMATIC
SOMEWHATANNOYED
I was driving home late last night in a pouring rain when the battery light came on. The instrument panel lights were flickering and I assumed that I would be stranded on the freeway, but I managed to make it home (about 25 miles) without losing power.
This morning I checked the battery with a volt meter(analog) which showed a little under ten volts. I started the car with no problem and noticed that the battery light was not on.
I checked the charging voltage and the needle was jumping erratically between 13 and 14 volts. I turned on the headlights and every other electric item I could think of but still no battery light.
I now have the battery charging but I'm confused as to what I may be dealing with.
Ideas?
Thanks
Feb 14, 2009 at 10:55 AM
MERLIN2021
  • 17,250 POSTS
You may be dealing with a siple belt slip...has the serp belt and tensioner been replaced yet? 135,000 you are close to needing them!
Feb 14, 2009 at 12:27 PM
SOMEWHATANNOYED
[quote:5011bcc0df="merlin2021"]You may be dealing with a siple belt slip...has the serp belt and tensioner been replaced yet? 135,000 you are close to needing them![/quote:5011bcc0df]
Thanks for the reply! I replaced the belt and tensioner about 9 months ago, but upon further inspection it seems a little on the loose side. I suspect that with a lot of water on the roads that the belt was slipping just enough to cause a low charge situation.
I've charged the battery and run the car at idle with the headlights on high, the A/C and radio on and the alternator is charging at between 13 and 14 volts, and the battery light doesn't come on, so until I see another problem I'm going with the loose belt theory.
Thanks again!
Feb 14, 2009 at 1:56 PM
MERLIN2021
  • 17,250 POSTS
Ok good luck.
Feb 15, 2009 at 4:45 AM
