1995 Chrysler Sebring Replace Starter Motor
1995 CHRYSLER SEBRING
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
FREDDAY
How much does it cost to replace a starter moter
Dec 3, 2008 at 11:45 PM
ZACKMAN
  • 4,202 POSTS
Can you turn some wrenches? Because if you can, you will save yourself the neighborhood of $200. $100 instead of $200 if purchased from the shop and 1.5 hours of labor charge. It only takes 30 minutes.
Remove battery terminal
Raise vehicle
Crawl under the vehicle
Remove oil filter (obviously put a drain pan under it before you do)
Remove 2 electrical connectors
Remove 3 mounting bolts
Remove starter assembly from vehicle
Install is reversed
Jan 2, 2017 at 11:43 AM
