1995 Chrysler Sebring Intermitent Stalling-RPM's drop off
1995 CHRYSLER SEBRING
150,000 MILES • 6 CYL • FWD • AUTOMATIC
A&C STARTEK
This vehicle will intermitently stall and or rpm's drop off and it almost stalls. Is not temp. related-will occur hot or cold does seem to happen more when cold.Has had spark plugs, wires, fuel pump, crank sensor replaced, fuel filter replaced. Once when stalled was able to check for spark before it restarted and there was no spark. most other times it restarts right away or sometimes it does stall, RPM's will drop off at then engine seems to catch again.
May 26, 2010 at 4:06 PM
LOUISL
  • 4 POSTS
FIRST THING, check the distributor after ALL the easy stuff. Ignition Coil could be bad. My mechanic got a big enough discount on the CARDONE remanufacture to justify his labor cost. Less than half of the cost of the dealer distributor $1100!
Jul 3, 2010 at 6:41 PM
