2008 Chrysler PT Cruiser oil filter change
2008 CHRYSLER PT CRUISER
25,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAXH
how to change the oil filter on my chrysler pt turbo and what is best oil
Oct 19, 2009 at 6:19 PM
CHRYSLERTECH
  • 11 POSTS
on the turbo pt you will notice that the oil filter is not very easy to get off i would use a band oil filter wrench or oil filter plyers.you will also need a 13mm to remove the drain plug.The best oil for that car is a 5w-30 synth blend.
Oct 31, 2009 at 7:33 AM
MAXH
Thanks so much for info.
can I just change to synthetic oil or must I wash old oil out first as I do not know what oil is in the car now?
Oct 31, 2009 at 9:15 AM
CHRYSLERTECH
  • 11 POSTS
I would not use full synthetic oil i use sythetic blend in everything i own but that is up to you. their is nothing special you need to do just drain all of the oil out and change your filter and put in your oil
Nov 2, 2009 at 8:09 AM
