The A/C in my PT Cruiser has stopped working. I can turn the air on and I hear what seems to be the motor running but no air is blowing from the vents. Occasionally the air blows from the vents and everything is fine, then the next time I start the air, nothing comes out of the vents. In every setting whether it be panel, floor, or defrost, the air does not blow, also the temperature setting doesn't fix the problem. The air doesn't blow whether it is on cold or hot or in between.
Nov 16, 2009 at 11:58 AM
