My windshield washer isn't working and I can find no fuse for it. Where would it be? The wipers work fine.
Feb 23, 2010 at 3:10 PM
BMRFIXIT
CERTIFIED EXPERT
If wipers operates when washer fluid don't assume fuse and switch ok check and suspect W/W pump or wiring
Pump is located at the lower end of the W/W tank
Ask a helper to operate the switch as you check the motor
If motor operates check for a pinch hose or a clogged nozzle
Feb 23, 2010 at 9:36 PM
CHEDMAT
MEMBER
Where is that fuse box located? I know of two in the car. One in the lower dash area and one behind of the air cleaner.
Feb 24, 2010 at 11:01 AM
BMRFIXIT
CERTIFIED EXPERT
Lower left side of dash Use a test light and test all the fuses best and sure way to eliminate a bad fuse
