2005 Chrysler PT Cruiser high idle
2005 CHRYSLER PT CRUISER
Engine Performance problem
2005 Chrysler PT Cruiser 4 cyl Automatic
I had to change the water pump on my car 2 months ago, as you know i had to take off the timing belt to do so. Now i am having problems with the idle being to high and it spits and sputters all the time i recently changed the spark plugs and wires and plug 1 had oil on it. I know that is not good. i am sure the timing is right. I also replaced the cam sensor that helped alittle because it doesnt die when it sits anymore. So any suggestions on what to do now. or any other sensors that could be replaced to fix the problem. i am ready to have it sent back to the dealer.Thank you
Jan 29, 2010 at 7:16 PM
BMRFIXIT
  • 19,053 POSTS
I read that you are sure that the timing is OK and I thought so on the one we had for a week with a similar problem until we took a closer look at the timing belt again it was no correct 1 tooth of I would take another look at the timing belt had no problem prior the timing work !
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_647.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_305.jpg
Jan 31, 2010 at 7:21 AM
