We had a leak in the head gasket and it was replaced and after that the engin light comes on and when hooked up to a computor it calls out #3 cylonder and later #1. All the plug look fine. It idles real rough and when stepping on the gas when out on the highway, it skips out. When I turn on the air cond. it even runs so bad that I think it will die out sitting at a stop light, it does run better in park. Also when it idles rough the head light flicker or when the cooling fan kicks in it idles rough and the head lights flicker. thanks
May 30, 2009 at 12:50 PM
