2003 Chrysler PT Cruiser Gurgling/Bubbling Sound
2003 CHRYSLER PT CRUISER
106,000 MILES • 4 CYL • FWD • AUTOMATIC
WARBIRD50
  • 5 POSTS
What causes a gurgling sound in PT Curisers when the engine is shut off after dirving the car for at leasta half hour
Apr 29, 2009 at 8:44 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Are you operating the AC ? Does noise come from under dash or engine compartment?
Let me know
Thanks for donate
Apr 29, 2009 at 11:17 AM
WARBIRD50
  • 5 POSTS
The air conditioner was running. Although this morning it was not running. The noise is coming from the engine compartment back by the firewall
Thanks
Apr 29, 2009 at 1:11 PM
DOCFIXIT
  • 18,828 POSTS
It maybe the heater core has the coolant been changed lately or work done on cooling system?
Also has gurgle always been there?
Apr 29, 2009 at 3:00 PM
WARBIRD50
  • 5 POSTS
The gurgle noise started about 2 months ago, but it was only happening once in awhile. This past week it's happening every day and lasts up to 5-8 minutes after I turn the engine off. Yesterday the radiator was flushed and the coolant replaced.
Thanks
Apr 29, 2009 at 3:06 PM
DOCFIXIT
  • 18,828 POSTS
Did gurgle change after flush and fill. Trying to out this together does it do it withAC off? Have you opened hood to get a listen ?
Apr 29, 2009 at 3:25 PM
WARBIRD50
  • 5 POSTS
The sound did not change but the length of time did. It lasted only about 45 seconds this AM. It does it with the AC on or off. Yes I've heard it with the hood open, and it sounds like it's coming from the middle of the engine by the firewall
Apr 29, 2009 at 3:41 PM
DOCFIXIT
  • 18,828 POSTS
Try this right below the radiator cap there is a bleeder valve, small nipple. Remove radiator cap engine cool. open bleeder start and let warm up add 50/50 mix as needed run unril only coolant comes out no air. Also get a new cap to make sure system is properly pressurized.
Apr 29, 2009 at 4:15 PM
WARBIRD50
  • 5 POSTS
Will try and let you know Thank you
Apr 30, 2009 at 8:33 AM
