2003 Chrysler PT Cruiser DELLAR
2003 CHRYSLER PT CRUISER
99,000 MILES • 4 CYL • FWD • MANUAL
DELLMAR
i would like to know if my clutch is screwed? i went from 120 to 60 in a second or two from 5 to 2 gear honest mistake the gears are too close on these cars. anyway i couldnt put it into gear at that time unless i jammed it really hard! but then it crawled really slow. so i left it and got it towed in. Now! its been about a month started the car last night gears work fine i can clutch no problem hell i can even drive the car but barely give it gas cause then the rpms run up and its not catching or so i think? if i let it crawl then keep feeding gas really slow it starts to pick up in speed then i clutch to next gears as long as i give it little gas i can move, can you tell me the problem please thanks
Mar 11, 2010 at 7:53 AM
DOCFIXIT
  • 18,828 POSTS
Damaged clutch disc overheated and is slipping.
Mar 11, 2010 at 10:31 AM
