2002 Chrysler PT Cruiser WHEEL BEARINGS
2002 CHRYSLER PT CRUISER
100,000 MILES • 4 CYL • FWD • AUTOMATIC
CLAYWILEY
HOW MUCH SHOULD IT COST TO REPAIR WHEEL BEARINGS?
Feb 17, 2010 at 1:17 AM
ERNEST CLARK
  • 1,730 POSTS
The front wheel bearings are $40 dollars apiece. The labor is 1.3 hours per side, which will be about $100-$130 per side, double for both.
The rear bearings are replaced as a complete hub assembly. Each hub will run you $60 apiece. Because these are a lot easier to replace, labor will be half-hour for each side. That adds up to $30-$50 in lobor for each side, double for both.
Feb 19, 2010 at 8:20 AM
