2002 Chrysler PT Cruiser Timing Belt has been changed, now
2002 CHRYSLER PT CRUISER
CATHYSUPINA
  • 11 POSTS
Shakes or Wobbles problem
2002 Chrysler PT Cruiser 4 cyl Automatic 83000 miles
We recently had the timing belt changed because we had to replace the water pump. Right after I drove the car off the lot, I noticed a slight idiling when I started to stop.
The check engine light has not come on. Could this be the result of putting the timing belt on wrong or a bigger problem that the mechanic did not see.
Jul 20, 2010 at 11:32 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
Thank you for the donation,
In you question you wrote... I noticed a slight idling when I started to stop.......
Can you elaborate on this a bit more, i am not sure as to what you mean here.
mark (mhpautos)
Jul 21, 2010 at 1:11 AM
CATHYSUPINA
  • 11 POSTS
When I start to slow down and right before I come to a full stop the car will idle. Itr seems like it idles somwhere between slow down and full brake force. It runs perfectly when I am crusing down the road, and no check engine light has ever come on.
Jul 21, 2010 at 9:13 AM
