2002 Chrysler PT Cruiser OIL IN TRANSMISSION
2002 CHRYSLER PT CRUISER
75,214 MILES • 4 CYL • 2WD • AUTOMATIC
JACKIE TAYLOR
ON A RECENT ROAD TRIP MY OIL LIGHT CAME ON. I CHECKED THE OIL LEVEL AND IT WAS LOW. I PUT IN TWO QUARTS AND THE CAR STARTED SMOKING. AFTER IT COOLED DOWN I CHECKED THE LEVEL AGAIN AND IT SHOWED LOW. I CHECKED THE TRANSMISSION AND IT SHOWED OVER FULL. HOW DOES ENGINE OIL GET INTO THE TRANSMISSION? I'VE REMOVED THE TRANSMISSION COOLER AND IT DOESN'T SHOW DAMAGE. THE ENGINE IS A TURBO.
Sep 24, 2010 at 10:42 AM
WRENCHTECH
  • 20,761 POSTS
The only way that happens is if someone actually pours it into the transmission. If you actually got motor oil in the transmission, then you have some serious problems now. Engine oil will destroy the transmission in real short order.
Sep 24, 2010 at 11:00 AM
