when the engine runs for half hour or about 15 miles the engine sputters and dies. the cooler the weather the longer the car runs. The pcm has been replaced and reprogramed by a professional. there are no trouble codes on the pcm. I checked fuel pressure and it was at specs even when the engine died. I installed new spark plugs with the correct gap. I ran the car untill it died and checked for spark. I put a spark plug in the 1 plug wire and when i cranked the engine no spark. when it cools off it runs. did coil check cold and was at specs .when hot not even close. unplugged crank senser and it did set an error code. I think the coil is bad what do you think?
Jul 22, 2010 at 9:34 PM
