Drive Train Axles Bearings problem
2002 Chrysler PT Cruiser 4 cyl Front Wheel Drive Manual
Replaced a clutch with visible wear after it jammed and wouldn't engage. Went to test drive, clutch master cylinder pushrod broke, had to replace the whole cylinder. No bleed valve, bled by pumping as in installation instructions, no pressure building except an inch off the floor, never gets more than that. No movement at all at the clutch release cylinder(clutch slave cyl). Replace it?
Mar 7, 2010 at 6:19 PM
